Hello Guest it is November 23, 2026, 05:06:48 AM
Author Topic: Mach3 problem with writer wizard  (Read 18820 times)
Offline JAC
  •  57 57
« on: November 04, 2019, 08:57:28 PM »
Hi everybody hope someone can help me. Im using the Mach3 demo version to learn and see what it can do before buying the license.
The problem I have, and I like to know if the write wizard works on the demo version, I have read on some post that it does but when I try to use it , it wont let me type any inputs (numbers), if I type 1 for tool # when Im going to the next like feed rate it change the tool # to 0 and it does that on any other I type for. it change everything back to 0.
Any help be appreciated in advance.
Thank you.
  •  9,378 9,378
Re: Mach3 problem with writer wizard
« Reply #1 on: November 05, 2019, 12:32:46 AM »
Ji JAC,
After you type a number hit the Return (Enter) key.
(This applies to most, if not all, Mach keyboard entries).
Offline JAC
  •  57 57
« Reply #2 on: November 05, 2019, 03:34:20 PM »
Thank you that works. Now to see how it works and what can I do it with my machine.
Thank you.
