Hello Guest it is October 21, 2026, 09:11:37 AM
Author Topic: Cam lobe generator ?  (Read 141522 times)
« on: October 22, 2019, 10:03:06 AM »
 :) Hi folks.
I've got a project that requires a cam lobe of specified duration running in a yoke/fork with minimal clearance through complete revolutions.
 Say the yoke/fork had a 2" opening. A 2" diameter cam follower offset .1" from its shaft centerline would oscillate the yoke .2 per revolution.
But ......
I want an egg shaped cam lobe that will have a duration of lift as much as possible per revolution but always measure 2" diameter at any point as to keep the yoke/fork free of backlash. I assume it would be shaped sort of like a guitar pick.  ::)
Is there a formula, or generator for this sort of thing ?
I can make a crude sketch if necessary.
Thanks.
Re: Cam lobe generator ?
« Reply #1 on: October 22, 2019, 10:18:01 AM »
In the attached, can I assume that as long as the red and blue are exact mirror images of one another that the OD would be the same anywhere around the periphery ?
« Reply #2 on: October 22, 2019, 10:22:47 AM »
uh .... nope. I see that wont work ...... standing by  :)
« Reply #3 on: October 22, 2019, 10:42:33 AM »
Arts Gearotic might help?
http://gearotic.com/
« Reply #4 on: October 22, 2019, 10:49:13 AM »
That did cross my mind. I have it on a different pc, will check it out, thanks.
« Reply #5 on: October 22, 2019, 11:47:11 AM »
Didn't see anything related in the SW, might ask on their forum.
Here is an example of a triangular cam and yoke I found.
The radius's of the cam are ever changing but the ramp up and down at the duration segment are relatively gradual, not a pure motionless dwell but blended closely enough for practical purposes.
This is giving me a worse headache than the Wankel engine  :P  :o
Cheers  :D
« Last Edit: October 22, 2019, 11:52:17 AM by Overloaded »
« Reply #6 on: October 22, 2019, 01:36:48 PM »
Found a link to exactly what I need, just need to figure how to draw it so I can cut it out with my nc mill.
https://www.youtube.com/watch?v=bSVPOGibdHA
I can get it pretty close with cad but wondering if there is a "dead nuts" way/formula/generator out there.
Russ
« Reply #8 on: October 22, 2019, 03:14:43 PM »
Thank you Brett, Graham and especially Mr. Reuleaux  ;)
All is good now.
« Last Edit: October 22, 2019, 03:19:11 PM by Overloaded »
« Reply #9 on: October 22, 2019, 03:49:04 PM »
Graham knows all them fancy words! Reuleaux, who would have thunk?
