Hello Guest it is October 22, 2026, 05:55:05 PM
Author Topic: Motion pauses on input signals  (Read 5204 times)
« on: October 21, 2019, 08:49:34 AM »
It's been awhile since I've been on here.
I'm running into an issue that I haven't come across before.
While my machine is moving whether it is from G Code, MDI, or Button Press (IE GOTO Work Zero) the machine will sometimes pause the motion if I press one of my control panel buttons, Tool Release, Coolant, etc.
I'm not sure if this is a HiCON issue, stepper issue, or Mach issue.
I'm using Nema 23 closed loop steppers, I haven't used steppers in a while, but I've never had this happen with them before.
I've increased the buffer in the HiCON plugin to no avail.
I'm not really sure what's going on.
Chad Byrd
