Hello Guest it is September 16, 2026, 12:52:58 PM
Author Topic: running mach3 off a memory stick  (Read 7848 times)
« on: October 17, 2019, 05:49:54 AM »
Can I run mach3 off a memory stick?
I am using windows 10
best regards
fred evans
  •  9,372 9,372
Re: running mach3 off a memory stick
« Reply #1 on: October 17, 2019, 07:21:06 AM »
Hi Fred,
I am assuming you are meaning a USB Memory Stick in which case NO.
You could try but you are certain to run into problems.
« Reply #2 on: October 18, 2019, 03:55:19 AM »
Thanks tweakie!!
best regards
fred
