Hello Guest it is November 07, 2026, 10:39:20 AM
Author Topic: problem with import dxf in lazicam  (Read 9672 times)
« on: September 11, 2007, 01:59:37 PM »
good morning , i want to try lazycam but i have a problem when i import dxf.So i start lazicam , i import dxf and the screen is to solidify.
The computer is to solidify and i am to oblige restart my computer.
Do you know why ??
My configuration is windows xp sp2, procesor core duo 1.6, and motherboard p55-mx se
thank you for your help
excuse me for my bad english
fabrice
Re: problem with import dxf in lazicam
« Reply #1 on: September 12, 2007, 06:47:31 PM »
Greetings Fabrice,
Is your .dxf file in AutoCad Release 12 format? This helps much. If your computer must be restarted, make sure you look at the dotnetfix.exe sticky posting. There is a file from microsoft you need to download and run because if you don't, you computer will freeze. I hope this helps. That computer should not be the problem. I think your English is fine.
Ergoman
