Hello Guest it is October 30, 2026, 12:36:58 PM
Author Topic: Another tool zeroing...but unique...  (Read 19536 times)
« on: October 13, 2019, 05:31:57 AM »
Ok guys...I am hoping someone else has had this issue crop up.
For quite some time I have set my tool length and height by the tried and tested paper method.
But as with all things progress must happen for profit.
But now I cry......
What's happening is that when I setup my auto tool zero device I wire it as directed.  One lead to 5vpc....one lead to pin 11....and one bridging the 5vpcgrnd to the ground for limits and e stop.
Now when the unit is activated and the digitize diagnostic icon/light turns on when the touch plate touches the tool ok....I manually lift it to the tool tip...I will explain why in a sec....so I safely assume my wiring at this stage is correct.
Buuuuuuuut.....I have no motor axis movement at all.....I cannot jog, mid or have a program move the equipment.
If I remove the wiring and disable the probe I have full control of my axis movement.
I have this breakout board and using this instructable to make the touch plate.
https://www.instructables.com/id/Mach3-Zero-Probe-Tool/
If anyone has had this issue before....please educate me....
Jacob
Re: Another tool zeroing...but unique...
« Reply #1 on: October 13, 2019, 08:42:18 PM »
The probing input HAS to be an independant input. It cannot be combined with limits or homes.
Just a thought (;-) TP
« Reply #2 on: October 13, 2019, 08:46:19 PM »
Yeah....I thought as much, but the probe ground has to share the grounding pin.
But if that was the case it would just trip an e stop error when contact was made to close the circuit.
Anyhow.....back to the paper method.
Offline ZASto
  •  434 434
« Reply #3 on: October 14, 2019, 03:30:05 AM »
Your probe should be connected as per attached image.
My personality is who I am.
« Reply #4 on: October 14, 2019, 03:56:36 AM »
Thank you....I tried this approach to no positive end...it seemed as there was no power going to the circuit through the probe...
  •  9,375 9,375
« Reply #5 on: October 14, 2019, 04:03:16 AM »
I think you need to apply the 12V to 24V power to your breakout board for the inputs to work ?
« Reply #6 on: October 14, 2019, 05:15:29 AM »
Done that....have 12-24 for power and running 5v for signal conditioning....
  •  9,375 9,375
« Reply #7 on: October 14, 2019, 06:35:08 AM »
Check you have your Probe Input (Mach3 Ports & Pins) Enabled, set to Port#1, Pin11, Active Low.
« Reply #8 on: October 14, 2019, 01:38:24 PM »
Yep.....used tool auto setter.....that's the entries it made.....
  •  9,375 9,375
« Reply #9 on: October 15, 2019, 12:55:14 AM »
So with your probe connected as ZASto has suggested you are still not able to make any motor axis movement ?
