Hello Guest it is October 30, 2026, 03:01:51 PM
Author Topic: Parallel Port Output Voltage  (Read 12584 times)
Offline Daner
  •  32 32
« on: October 11, 2019, 06:21:18 PM »
My Mach3 is not communicating with the cnc router.
Testing the parallel port, I get 3.4 volts on most of the pins on the 13 side without pressing any keys page up, down left ,right etc
On the 12 pin side I get no voltage at all ,even when I press the up down side to side X,Y,Z
This kind of tells me a setting is not right?
Should I be getting volts through the Parallel ports pins for ie, up- down - side to side ?
Thanks in advance for any help.
Offline Daner
  •  32 32
Re: Parallel Port Output Voltage
« Reply #1 on: October 11, 2019, 07:48:17 PM »
On my control panel for Mach 3
It shows the XYZ sending to the monitor.
I just need to find out why it’s not sending to the parallel port.
Please help
  •  9,375 9,375
« Reply #2 on: October 12, 2019, 12:49:59 AM »
In Device Manager check the Address of your LPT Parallel Port and then check that is the address you have entered for Port#1 of Mach3 and that it is enabled.
Offline Daner
  •  32 32
« Reply #3 on: October 12, 2019, 10:55:08 AM »
Looks like they match and enabled
  •  9,375 9,375
« Reply #4 on: October 13, 2019, 12:33:59 AM »
Perhaps try running a parallel port tester just to check that is working OK.
This or something similar; https://www.downtowndougbrown.com/2013/06/parallel-port-tester/
Offline Daner
  •  32 32
« Reply #5 on: October 13, 2019, 09:50:36 AM »
I reinstalled Mach
And turned on 2 ports
And it works
  •  9,375 9,375
« Reply #6 on: October 14, 2019, 12:41:46 AM »
Excellent  ;)
