Hello Guest it is October 25, 2026, 03:15:54 AM
Author Topic: Can soft limits be applied to only 3 of the 4 axis?  (Read 7898 times)
« on: October 10, 2019, 02:27:18 PM »
I like soft limits!  Soft Limits does not like my 4th axis (the extruder on my 3d printer) and often during a print I exceed the limits (not sure how cause I have the limits set to 10M but it still trips) and program stops running.  Is it possible to disable soft limits for just 1 axis?  Thanks
Re: Can soft limits be applied to only 3 of the 4 axis?
« Reply #1 on: October 10, 2019, 03:21:06 PM »
If your 4th is set up as  angular you can isolate it in Gen Fig.
Works here using hotkeys.
Seems to work with A as angular unchecked as well.
