Hello Guest it is October 24, 2026, 10:20:44 PM
Author Topic: Reinstalling Mach 4 on New PC  (Read 7000 times)
« on: October 07, 2019, 05:33:57 PM »
My old computer died, but i had made a copy of most of my program information and data including all of my Mach 4 and Pokeys data. When installing Mach 4 on my new pc, what files do i replace in the new installation from my old pc. Will this only work if i am using same version of Mach 4 and same version of plug-in. I tried a couple things, but encountering issues. I really would like to avoid having to go through entire set up process as it has been almost 2 years since i had originally done this and see that the newest version of Mach 4 has a few added features i would like to take advantage of. Sorry if this has been asked before, but i did not see a concise solution or the post was older.
Re: Reinstalling Mach 4 on New PC
« Reply #1 on: October 09, 2019, 10:06:57 AM »
Typically the only thing that needs to be saved is the profile. But if you have done any customization you will need to save anything you customized.
