Hello Guest it is September 09, 2026, 06:49:04 AM
Author Topic: Turn | Is eccentric turning possible with Mach4?  (Read 18043 times)
Offline Azalin
  •  189 189
« on: October 06, 2019, 02:02:28 PM »
I have a 2 axis lathe with encoder on the spindle. I use SolidWorks/SolidCAM to generate g-codes. No problems at all. Only thing that I wasn't been able to get SolidCAM to post a simple eccentric turning program. So I guess SC doesn't support eccentric turning at all.
Question is how can I write a program to cut a piece like in the attached image?
Suat
Offline smurph
  •  1,575 1,575
Re: Turn | Is eccentric turning possible with Mach4?
« Reply #1 on: October 06, 2019, 03:34:51 PM »
There is nothing in standard G code that specifically does this.  Hence why SolidCAM would not post a program to do it.  There may be machine that have custom G codes for this type of operation though.  And it would have a specific post processor for SolidCAM to use it.
If your motion controller is capable of real time gearing of the X axis motor to the encoder on the spindle, you could do something like this.  For instance, I know a Galil could do this.
Otherwise, to me, this would be more of a 4th axis milling type of operation.
Steve
« Reply #2 on: October 06, 2019, 05:41:07 PM »
one other alternative is to approximate the shape in Gcode.
I, some time ago, generated some Gcode that allowed a lathe to cut a hex by moving the X axis in and out in
synchronicity with the C axis (spindle). You could do the same thing but instead of a hex make it an eccentric.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #3 on: October 06, 2019, 07:21:47 PM »
You also need a Y axis to keep the tool on the centre line, you are in effect producing a circle with the tool in the XY plane.
« Reply #4 on: October 06, 2019, 08:15:44 PM »
I seem to recall NOT having to have a variable Y axis when 'turning' a hex, and I likewise cant imagine that you would need a variable
Y axis to turn an eccentric.
I'll try to find the post that had the hex code.
« Reply #5 on: October 07, 2019, 04:21:45 PM »
stick with me here...this may take a couple of posts to flesh out.
I have attached a pic of an eccentric circle of radius r with its centre displaced from the rotational centre of the lathe
by a distance d. As the job rotates (increasing theta) the centre of the eccentric describes a circle with components:
x'=d cos(theta)
y'=d sin(theta)
According to the diagram we require the distance r' from the lathe tip to the lathe centre as a function of theta.
r'=(r2-d2sin2(theta))1/2 -d cos(theta)
All that is neccessary is to generate gcode moves at sufficiently fine intervals of increasing theta.
Will come back with some details.
« Last Edit: October 07, 2019, 04:23:30 PM by joeaverage »
« Reply #6 on: October 07, 2019, 04:30:36 PM »
whoops....my attached pic is upside down....this attachment may be easier to read.
Offline Azalin
  •  189 189
« Reply #7 on: October 07, 2019, 04:51:44 PM »
Thanks Craig
« Reply #8 on: October 07, 2019, 05:38:56 PM »
Hi Azalin,
as an example if the eccentric diameter is 50mm and its is displaced 10mm from the lathe centre:
r=50
d=10
With the spindle at 30 degrees theta =300
r'=(502-102sin230)1/2-10.cos(30)
   =(2500-100x0.25)1/2 -10x0.8660
   =49.749-8.660
   =41.089mm
Now if the lathe spindle rotates another degree so theta=31
r'=(2500-100x0.2652)1/2-10X0.8571
    =41.165mm
The Gcode that would link these two steps is:
g1 x41.089 c30
g1 x41.165 c31
This is clearly too painfully slow to calculate by hand so that's what Lua is for. Note I would calculate (using a Lua script) every 0.1 degree
or maybe even finer, thus I would use a macro as a sort of Wizard.
« Reply #9 on: October 07, 2019, 05:44:52 PM »
this approach will, as Graham suggested, put the lathe tool either under or over the centre line throughout the toolpath.
Depending on the material that may be a problem which could only be cured by having the Y height
move  synchronously.
