Hello Guest it is November 20, 2026, 12:07:36 AM
Author Topic: What replaces G79 for Mach3?  (Read 11615 times)
« on: September 11, 2007, 04:22:27 AM »
Hi all,
I am trying to create some g-code from VectorXT for use in Mach3.
The problem is the post processor is placing a G79 before the coordinates for the drill hole. I am using an isoacv10 post.
Is there a replacement just for this G79 or is there a good Post processor for use with Mach3, latest lockdown version.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: What replaces G79 for Mach3?
« Reply #1 on: September 11, 2007, 11:01:48 AM »
Machs drilling cycle is G81 Znnn Rnnn Fnnn, you can do a replace of the G79's
Znnn final Z depth
Rnnn Rapid point above work face
Fnnn feed rate
Graham.
« Reply #2 on: September 12, 2007, 10:40:39 PM »
Thanks Graham. I ended up using a different post that did something similar, replacing the G79's with G82.
