Hello Guest it is November 11, 2026, 09:30:42 PM
Author Topic: Lathe - Quadature configuration and setup  (Read 30798 times)
« on: September 23, 2019, 04:27:28 AM »
I have Mach4 & Pokeys up and running on a CNC4PC M16D board but I need an example of the proper PK Pin configuration. I get a true RPM reading when selecting the INDEX(lathe) but I get 1/2 the reading when selecting the Encoder(lathe). It seems that the ENC A & B pulses are not being processed. I have been using PK Pins 8, 12 and 13 but I don't think that I have them set up right.
Re: Lathe - Quadature configuration and setup
« Reply #1 on: October 20, 2019, 07:15:59 AM »
The True RPM is now reading correctly. In tracing the encoder inputs by unplugging the PoKeys and the C78 boards from the motherboard and reinserting them the displays are now functioning properly. I contribute it to a bad connection on one of the boards.
« Reply #2 on: January 25, 2020, 05:04:30 PM »
I am trying to get my m16d and pokeys 57e rigid tapping going also. do you think you might be able to help me please. I am not sure how to configure ports and pins, and everything. i sure ywould appreciate your help please thank you. playerofpawns@hotmail.com
