Hello Guest it is August 29, 2026, 02:27:47 PM
Author Topic: Opening g-code  (Read 36745 times)
Offline Seba
  •  23 23
Opening g-code
« on: September 20, 2019, 03:04:32 PM »
Hello. Please help, how do I set up Mach Counter in Mach Screens?
My second request was wanted on the desktop waving to insert keys with g-cods because I still mill 5 same items.
Thank you
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Opening g-code
« Reply #1 on: September 20, 2019, 07:22:55 PM »
Create a button a Label and a DRO on the screen of your choice.
Set the DRO to a user variable e.g. 1200
Set label to "Part Counter" and position close to DRO
Label the button "Reset Counter" and set it to run vb script
Enter VB code :-
SetUserDRO(1200,0)
Save screen.
Then on the end of every g-code file just before the M30 enter
#1200 = [#1200 + 1]
Or you can set up a Macro to do it
M1025.m1s
count = GetUserDRO(1200)
count = count + 1
SetUserDRO(1200, count)
« Last Edit: October 01, 2019, 09:57:18 AM by Graham Waterworth »
Offline Seba
  •  23 23
Re: Opening g-code
« Reply #2 on: September 21, 2019, 03:07:03 AM »
Hello.
thank you very much for your help, I can ask for a more detailed explanation because I know neither programming nor too much on Mach 3, so I would be very grateful for some file or video tutorial.
Offline Seba
  •  23 23
Additional button Mach Screens
« Reply #3 on: September 28, 2019, 04:01:40 PM »
hello how to add an extra button in
Mach Screens which will open g-cod from file C:\Users\Sebastian\Desktop\PRACA\CNC\ciastk.tap
Offline ZASto
  •  434 434
Re: Opening g-code
« Reply #4 on: September 29, 2019, 06:29:11 AM »
Enter VB code :-
setuserdro(1200,0)
Save screen.
#1200 = #1200 +1
Wel, Graham
The incrementing of the #1200 works, incrementing is not shown in DRO
Make no mistake between my personality and my attitude.
My personality is who I am.
My attitude depends on who you are.
Offline Seba
  •  23 23
Re: Opening g-code
« Reply #5 on: September 29, 2019, 10:33:43 AM »
What is wrong?
Offline ZASto
  •  434 434
Re: Opening g-code
« Reply #6 on: September 29, 2019, 01:19:47 PM »
Not incrementing DRO, user variable incrementing.
  •  2,785 2,785
Re: Opening g-code
« Reply #7 on: September 30, 2019, 11:21:03 AM »
Try a different DRO, #1200 may be in use by another macro
Offline ZASto
  •  434 434
Re: Opening g-code
« Reply #8 on: September 30, 2019, 05:38:12 PM »
You were right, I use 1200 for some other things, but...
even if I change the variable to, eg. 999 or 1000 (with corresponding changes in screenset), still no update of DRO.
It only works if I call a macro.
Code: [Select]
M1100.m1s:
counter = getuserdro(1100)
counter = counter + 1
setuserdro(1100, counter)
Anyway, I tried to help Sebastian since I do need counters :)
  •  2,785 2,785
Re: Opening g-code
« Reply #9 on: October 01, 2019, 09:52:17 AM »
That should not be a problem, just add the M1100 to the end of your program and it will work.
How did you want it to work?
