Hello Guest it is November 03, 2026, 09:41:30 AM
Author Topic: mach 3 toolchange issue  (Read 21305 times)
« on: September 18, 2019, 08:55:14 AM »
hello friends, i recently did some optimizing of my control pcs according to the steps shown in the 'ran out of data' help section. also, i made a couple of changes in the safe z set up settings in the config menu. i did not have any issues at first but now when i use the tool change button in my 2010 screenset the z goes all the way up and triggers an e stop. this is happening on both machines seperate control systems. also using ess if that matters. any ideas? im not sure exactly what i may have changed but something is not right. thank you in advance.db
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: mach 3 toolchange issue
« Reply #1 on: September 19, 2019, 03:24:11 PM »
If you go into the Mach3 folder you should be able to find and XML backup file from before you made the changes, rename the current one in use and copy the backup as the current name.
See if that helps
