Hello Guest it is November 22, 2026, 02:26:10 PM
Author Topic: Backing up Mach3 settings  (Read 8109 times)
« on: September 09, 2019, 05:08:56 PM »
Is there a neat method of backing up Mach3 settings?  With my upcoming move to Win 10 from Win 7, I will need to do a re-install.  Can I save all my settings and re-apply them?
  •  9,378 9,378
Re: Backing up Mach3 settings
« Reply #1 on: September 17, 2019, 01:45:57 AM »
Your Mach3 settings are contained in <your profile> .xml file. If you have any special screen features then they are saved in you screen .set file (typically 1024.set). If you have any special Brains or Macro's then they are saved in their respective folders. Your Mach3 license is saved as Mach1Lic.dat. All the above are in the Mach3 folder.
The safe bet is to make a secure backup of the complete Mach3 folder then, if necessary, copy the relevant files / folders to your new installation.
