Hello Guest it is November 13, 2026, 07:39:42 AM
Author Topic: Y axis problem in CNC router  (Read 8962 times)
« on: September 09, 2019, 08:46:16 AM »
     Hi,  My CNC router has just stopped working properly. When I press the Y axis key on the keyboard of my PC, which runs Mach 3 software, the Y axis does not move, Instead of the Y Axis jogging, I just hear a buzzing sound. The X axis moves normally when jogged. When I swap the X & Y plugs that come out of the CNC controller box I get the same results except that I have to press different "Arrow" keys on the PC keyboard. It seems like it may be motor or cable connect problem. Any ideas?
Cheers   Gary
Re: Y axis problem in CNC router
« Reply #1 on: September 10, 2019, 10:20:23 AM »
I've had that kind of problem before...
So you're saying you can get the y-axis to run if you switch the cables coming out of the control box?
That would mean the Y-axis motor is ok mechanically.
On my machine I had a gecko drive go bad.  When I replaced it, it ran fine.
« Reply #2 on: September 11, 2019, 05:26:13 AM »
Thanks for the help but on close inspection I found that on of the pins had popped out of a plug to the Y axis. When it was pushed home everything worked.
