Hello Guest it is November 13, 2026, 08:54:02 AM
Author Topic: Mach3 Auto Calculator decimal problem  (Read 8358 times)
Offline Shaom
  •  13 13
« on: September 02, 2019, 10:27:08 AM »
Hi!
I have a problem with auto calculator and decimal values on wizards.
It only accepts integer value and doesn't accept numbers after the decimal point.
For example - i want to put 2.33 - auto calculator stops in 2.
When i put numbers with usb keyboard - i can do it without any problem.
Thanks for Help!
Re: Mach3 Auto Calculator decimal problem
« Reply #1 on: September 02, 2019, 01:56:10 PM »
Hi Shaom
one reason could be your used regional settings. Perhaps you try a region which uses  a dot "." as separator (e.g. US).
Klaus
The brain isn't a soap, it doesn't shrink when used.
Offline Shaom
  •  13 13
« Reply #2 on: September 03, 2019, 01:24:53 AM »
Great advise! Its working now :)
Thank You :)
