Hello Guest it is November 19, 2026, 07:13:02 AM
Author Topic: Show first line of G-Code  (Read 18842 times)
« on: August 30, 2019, 02:17:49 PM »
 I am working on creating a custom screen set for myself. I would like a text line to show the first line of code from my g-code.
Basically my first line of code is the "name" of the saved tool path. I would like a text line to always show the name of the running toolpath.
Can some one help me with a script or code for this?
Thank You
Offline TPS
  •  2,627 2,627
Re: Show first line of G-Code
« Reply #1 on: August 31, 2019, 01:37:21 AM »
if you are talking about Mach3, a Label with Content File will Show you the filename of loaded program.
i do not know about a possibilty to Show only the first line of gcode, except your create a VBScript witch is
used every time you load a new file, this will only work with a button on Screen, not with Standard menue load file.
« Reply #2 on: August 31, 2019, 05:09:35 AM »
Thank You. I'll keep trying. If I figure it out I'll post it.
