Hello Guest it is November 23, 2026, 03:04:07 AM
Author Topic: Should Feedrate Override affect Step Jog Speed or Continuous jog speeds?  (Read 6925 times)
Offline jevs
  •  315 315
On my Machmotion X15-10-01 Control Panel when used with Mach3, the Feedrate Override switch would also slow down or speed up the incremental jog speed.
I thought it also affected it in the different Continous Jog % settings, but I cannot recall for sure and the manual only specifies this:
"With the Feedrate Selector you can adjust the feedrate override from 0% all the way to 130%. You can use it to slow your machine down while running a program. Also, in step jog mode the speed of the axis is regulated by the Feedrate Selector."
I do not have to stick with this way of doing things, but I am not sure how FRO should work in relation to Manual jogging normally? It seems that stock Mach4 FRO does not affect incremental or continous jogging.
Looking for some advice how I should do it.
See page 5 and 6 for the control panel I am using.
https://machmotion.com/documentation/CNC%20Controls/X15-200/X15-200%20User%20Manual.pdf
Offline smurph
  •  1,575 1,575
Re: Should Feedrate Override affect Step Jog Speed or Continuous jog speeds?
« Reply #1 on: September 11, 2019, 01:04:22 AM »
You are correct, the stock FRO doesn't affect any type of jog.  The Jog Rate affect jogs.  The slider on the bottom of the jog panel in a stock screen set or the Continuous Jog on that panel you have.  FRO should NEVER affect any jog rates.  That is purely for G code feeds.
Steve
