Hello Guest it is November 24, 2026, 06:10:38 PM
Author Topic: Mach 4 Automaticly open GCode ?  (Read 9137 times)
« on: August 21, 2019, 02:56:20 PM »
Looking to see if anyone can help me
I made a little program in VB.NET to make some gcode
I am looking to see if it is possible when i click the save button
it will automatically open my file in Mach4
Would anyone how to do that ??
Re: Mach 4 Automaticly open GCode ?
« Reply #1 on: August 22, 2019, 10:37:33 AM »
Mach4 takes a few command line parameters like the /p for what profile to use and also a /o for which gcode file to load.  Your VB script would have to construct a command line with the profile and file.
C:\Mach4Hobby\Mach4GUI.exe /p MyMillProfile /o "C:\Mach4Hobby\GcodeFiles\FileToRun.tap"
« Reply #2 on: August 22, 2019, 12:31:49 PM »
use the dll option
i use it a lot very powerful
i have "work list" that load the program and run it on 2 computers with 2 mach system(labeling and cnc)
« Reply #3 on: August 22, 2019, 01:52:04 PM »
This is what i ended up using
Dim p As New ProcessStartInfo
        p.FileName = "C:\Mach4Hobby\Mach4GUI.exe" 'Apostrophes in a file path? eek
        p.Arguments = " /p Mach4Router /o C:\Mach4Hobby\Subroutines\run.txt "
        p.WindowStyle = ProcessWindowStyle.Maximized 'can be hidden
        Process.Start(p)
I am guessing the DLL option might work better ??
« Reply #4 on: August 22, 2019, 02:17:56 PM »
dll work perfect
can do any thing
« Reply #5 on: August 22, 2019, 02:25:06 PM »
you can see the attach(sorry for the language)
customer even not need see mach interface
then mach write status on text file and i can read it as event in my c#
« Reply #6 on: August 22, 2019, 09:19:57 PM »
That's Awesome
