Hello Guest it is November 13, 2026, 09:43:43 AM
Author Topic: Mach3 why fixture save and tooltable save on shutting down?  (Read 9297 times)
Offline Rimmel
  •  284 284
« on: August 15, 2019, 06:20:57 AM »
why fixture save and tooltable save on shutting down? Why? When I change the tooltable I save it.... yet should the machine crash it loses the settings. I haver to close the app to get it top save properly..
Any ideas?
Re: Mach3 why fixture save and tooltable save on shutting down?
« Reply #1 on: August 15, 2019, 11:59:32 AM »
Go to the Config button press, go to the bottom Save Settings and press.
Offline Rimmel
  •  284 284
« Reply #2 on: August 15, 2019, 01:45:45 PM »
Doesn't work. Still asks me to save tooltable on exit.
« Reply #3 on: August 15, 2019, 07:04:54 PM »
Yes it will ask you that. You can turn that off in config. But when you do teh save it does save to the file so it is saved other wise all changes are only saved at shutdown.
