Hello
Guest
it is
November 13, 2026, 09:36:18 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Mach3 not machining to scale
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Mach3 not machining to scale (Read 8962 times)
Caucau
3
on:
August 09, 2019, 03:18:05 AM »
Mach3 not following Gcode drawing to scale. Gcode made in Aspire 8.5.
Cutter should have travelled 500mm but only moved 20mm.
Manually jogging the correct distances as displayed on mach3 but when Gcode is loaded it machines 1/20th the scale drawing. Scale is set to 1. Can anyone advise what I'm doing wrong?
Logged
joeaverage
7,663
Re: Mach3 not machining to scale
Reply #1 on:
August 09, 2019, 03:27:04 AM »
is it 1/20th scale....or could it be 1/25th scale....or 1/25.4th scale to be precise. If so the machine is interpreting the Gocde
as millimeter scale but the Gcode is written in inch scale, ie the object turns out 1/25.4 th of full size.
Logged
Caucau
3
Reply #2 on:
August 09, 2019, 03:30:48 AM »
Gcode written in mm
Logged
Caucau
3
Reply #3 on:
August 09, 2019, 04:55:32 AM »
could it be related to the Configure Initial State settings or select native units - "set default units for setup" ( machine set to inches in "units for motor setup dialog")?
Logged
Print
Pages:
1
Go Up
« previous
next »
