Hello Guest it is November 22, 2026, 02:24:30 PM
Author Topic: Best Cam for 2 axis lathe?  (Read 7885 times)
Offline Azalin
  •  191 191
« on: August 06, 2019, 02:56:35 AM »
I use Mach4. I was doing fine with Mach4' canned cycles until yesterday. Yesterday I needed to cut a complex shape but I wasn't able to do it with Mach4 canned cycles.
I normally use SolidWorks with SolidCam but I could not find a proper post processor for Mach4. So, I need switch to another Cam software for lathe.
What Cam software should I use for lathe with SolidWorks + Mach4?
Thanks in advance,
Suat
Offline Azalin
  •  191 191
Re: Best Cam for 2 axis lathe?
« Reply #1 on: August 06, 2019, 02:58:20 AM »
The lathe is a retrofitted Sieg C6. Front tool post, spindle turns only CW. Very simple machine.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #2 on: August 27, 2019, 03:10:02 PM »
As long as you export the profile of the part as DXF most CAM systems will do simple 2 axis lathe, look at CamBam its very low cost.
