Hello Guest it is November 13, 2026, 04:23:24 PM
Author Topic: Pokeys57CNC with AMB 1050 FME-1 DI  (Read 32007 times)
« on: August 03, 2019, 10:20:55 AM »
Hello,
has somebody running Pokeys57CNC with an AMB (Kress) 1050 FME-1 DI (digital interface) with the 0-10V Output?
The AMB needs +24V, 0V and 0-10V. There is no dedicated GNDi for the 0-10V. 24V and 0-10V uses the same GND. Pokeys57CNC only offers isolated GNDi for the 0-10V. How can I connect the AMB to Pokeys57CNC?
I tried to connect GNDi to machine GND, but then I always get arround 5,6V, even when analog out is not activated.
Do I have to connect it to another PWM out with a small circuit to generate the 0-10V with the same GND?
Alex
Re: Pokeys57CNC with AMB 1050 FME-1 DI
« Reply #1 on: August 11, 2019, 02:03:59 PM »
I tried to set PIN 20 to PWM and give OemDRO 817 (Spindle Speed) as PWM out, but I only get 3,3 V and no PWM signal from mach3. When I use the Pokeys application, then I can set PWM and I can see the PWM signal with my oscilloscope.
Is there a problem within the mach3 plugin, so that PWM out is not working?
I build a small circuit with a LM358 to generate the 10V, but when PWM is not working, this is not possible.
« Reply #2 on: September 24, 2019, 05:12:40 AM »
Solution  was, to add a dedicated power supply for the AMB with no connection to the machine electric. Then it works with the isolated 0-10V output.
Now all is working fine.
  •  9,377 9,377
« Reply #3 on: September 24, 2019, 05:24:54 AM »
I am pleased you have it sorted and thanks for posting the solution.
« Reply #4 on: September 03, 2022, 08:48:46 AM »
Hello,
could you explain how did you wired the AMB spindle to the pokeys57cnc?
i can't contol spindle speed
many thanks
Vincent
« Reply #5 on: September 06, 2022, 02:56:37 AM »
To help , i found the solution.
Connect brown wire to PSU 24v+, green to 0-10v pin and you have to connect 3 GND :
- 24V PSU GND
- 0-10v GNDi
- GND from AMB spindle speed control (white wire)
Configure Mach4 with step to step tutorial from Pokeys57CNC
And all works well now :)
« Reply #6 on: September 20, 2022, 03:26:37 PM »
You were faster then I :-)
here is the schematic for pokeys and the AMB.
https://im.ge/i/1DhY1C
You need 2 dedicated power supplies. One for pokeys (6-28V) and one for AMB (24V). You have to be sure, that GND/0V is NOT interconnected between the two power supplies.
For mach3 set things, like in this post: https://www.machsupport.com/forum/index.php?topic=33174.msg230383#msg230383
Map PWM to DRO 817 in %, set Multiplier to 0.00417
https://im.ge/i/1DhV7r
For mach4 I have no info. Still use mach3.
Greetings
Alex
