Hello
Guest
it is
October 20, 2026, 08:48:33 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Mach 2, Continous Jog Not Functioning
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Mach 2, Continous Jog Not Functioning (Read 15272 times)
jsteward
4
on:
September 07, 2007, 05:12:11 PM »
Hello,
Having trouble with Continous Jog, Jog mode is ON, Step works fine, but continous will not do anything, the DRO nor the machine move in Continous Mode, HELP.
Re: Mach 2, Continous Jog Not Functioning
Reply #1 on:
September 10, 2007, 04:56:08 PM »
Press the Tab key and make sure your slow Jog rates is NOT set to 0%
jsteward
4
Reply #2 on:
September 10, 2007, 05:24:55 PM »
The tab key is for Mach 3, not 2, tab does nothing in mach 2.
Reply #3 on:
September 10, 2007, 05:28:33 PM »
Ah sorry, never even noticed MACH2 in the title, not used to seeing it so my brain (what little there is) tends to blank it. Cant remember where or if the slow jog rate is in Mach2 but I will install it and see if I can remember.
Reply #4 on:
September 10, 2007, 05:31:24 PM »
OK its on the main screen but cant be set to 0 anyway so more than likely its not your problem
jsteward
4
Reply #5 on:
September 10, 2007, 06:19:48 PM »
well, thanks for trying, NEXT!
Brian Barker
3,860
Reply #6 on:
September 11, 2007, 09:15:16 PM »
What happens if you hold down shift and try to jog?
Brian
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
jsteward
4
Reply #7 on:
September 12, 2007, 12:03:52 PM »
THAT WORKS!! WT$%&^&
I noticed that if I hold the arrow key down for a few seconds, which I had not done the motor is moving V-E-R-Y S-L-O-W-L-Y. What did I do and how do I fix it?
Thank you.
Brian Barker
3,860
Reply #8 on:
September 12, 2007, 12:10:51 PM »
hmmm ... Sounds to me like you have the slow fog rate set very slow...
Set the slow jograte to 100 and see if that helps
Brian
www.machsupport.com
Print
Pages:
1
Go Up
« previous
next »
