Hello Guest it is October 24, 2026, 06:27:52 PM
Author Topic: Mach4 ESS with Spindle and Laser Diode?  (Read 7715 times)
« on: July 24, 2019, 12:50:06 PM »
I have an Avid CNC Pro 48x48 using Mach4 (with an ESS) and I'm looking to add a diode laser into the setup.  I already have the stock 2.2kw spindle.  It's my understanding that the PWM control is already reserved for the spindle, is there a way to ALSO control a separate laser, or would I just have to physically switch between the two?  The laser accepts a PWM/TTL signal.
  •  9,374 9,374
Re: Mach4 ESS with Spindle and Laser Diode?
« Reply #1 on: July 25, 2019, 03:22:42 AM »
Unfortunately there is only one PWM signal available so I physically switch between Laser and Spindle.
« Reply #2 on: July 25, 2019, 09:57:41 AM »
Ah, bummer.  Do you just have two different profiles setup then?
  •  9,374 9,374
« Reply #3 on: July 26, 2019, 12:14:56 AM »
I am able to use the same profile.
Offline Pedio
  •  200 200
« Reply #4 on: August 03, 2019, 08:42:50 AM »
I use the spindle and a laser controller. They share the same PWM port. While I have the capability, I rarely use the laser power control. I many vary the feed speeds to get the desired effect - Slow gives more power / fast gives less.
I have two toggle switches on my machine. One to turn on the spindle and one to turn on the laser. I only turn on the one that I am using at the time. I don't have a reason to have them working in the same program. I use the same profile in M4 for both of these.
I have also rewritten my CAM post processor to take out all of those pesky Z axis moves so it does not defocus my laser while I am running a G code file for the laser.
I love the laser. I purchased one from L-Cheapo - 3W. It is solid state and will cut (thin stuff) or burn (cutting boards etc). I have not bought a gift in quite a while  :D
They have a new 10W solid state laser that will cut thin stuff. I may have to give myself this for X-mas.
