Hello
Guest
it is
October 24, 2026, 01:39:08 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
Mach4 General Discussion
X move starts before Z move finishs
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: X move starts before Z move finishs (Read 14588 times)
Raymondo
73
on:
July 20, 2019, 07:17:00 PM »
Hi
I am having trouble a Z feed does not get to zero before the next command starts to move and it seems to be feed dependant
G0 Z .25
G1 Z0 F55
X2.2 F100
this will start feeding the Z value until about .020" .030" before Z reaches zero then the X moves begins leaving a .150 to .200 long ramp
If I slow the Z feed down to say just 4 it seems to feed all the way down then do the X move
Do I have some thing set wrong some where
Regards Ray Hudson
Steve Stallings
529
Re: X move starts before Z move finishs
Reply #1 on:
July 20, 2019, 07:39:39 PM »
This can be caused if you are running in Constant Velocity mode using G64. This causes the control to blend moves, and that is bad for drill cycles.
Try inserting an Exact Stop mode command, G61 before the drill cycle.
Steve Stallings
www.PMDX.com
Raymondo
73
Reply #2 on:
July 20, 2019, 08:25:23 PM »
I use mastercam and I looked through and it is putting a G64 at the start of the code
Thanks I will test a G61 out tomorrow but am pretty sure you have the problem solved thank you very much
I think in the past in high feed moves I was getting larger radius on internal radius machining but could never figure it out so I think that will be the same problem
Regards Ray and thank again
Raymondo
73
Reply #3 on:
July 22, 2019, 08:31:56 PM »
I have tried the G61 and it cures one problem but it is so jerky doing compound curves etc that I can't use it
Also doing hi speed cut outs with G64 it cuts external 90 degree corners fine but internal corners 90 degree corners it puts a large radius instead of a sharp 90 degree corner and this radius is related to the speed of the feed so to my mind is not following the tools path and I think it is impractical to put a G61 before every internal corner and a g64 after and don't think the post processor could figure out to do that either
So I am at a bit of a loss how to tackle the problem
I am using a router and feed of 120 inch per minute and need to get down to say 6 IPM to make is follow the desired tool path
Regards Ray
TOTALLYRC
872
Reply #4 on:
July 22, 2019, 08:40:10 PM »
It sounds like you acceleration is too slow. Try increasing it a little at a time. You may also want to look at the CV wizard.
Mike
Raymondo
73
Reply #5 on:
July 22, 2019, 09:00:40 PM »
I did not know about the CV wizard and will have a good play I have not found any real explanation of how it works and what angle 1 angle 2 etc should be set to and what is means but I will set up a test piece and test it out as best I can the docs that came will mach4 on CV do not seem to be what I have for CV wizard
Mine had angle 1 set to 179 and the rest to zero
Regards Ray
Chaoticone
5,624
Precision Chaos
Reply #6 on:
July 22, 2019, 09:34:54 PM »
Run the CV distance tolerance wizard and read each screen............ the documentation is built in.
If you could see the things I have in my head, you would be laughing too.
Raymondo
73
Reply #7 on:
July 23, 2019, 02:47:41 AM »
Hi
I open the wizard there is CV_feedrate there do not seem to be any help screens there but I can alter the angle0=179 to what ever I want
there is also the mctuningwizard this I can move the sliders up and down but can't save or in fact get out of it with out doing a Alt Cntr Del it seems to lock up I also cannot read the bottom text in the screen or scroll it up
This is on my home computer in demo mode I will try on the machine tomorrow
regards Ray
Steve Stallings
529
Reply #8 on:
July 23, 2019, 07:40:28 AM »
Don't overlook the possibility of dynamically switching between G61 and G64 as needed so that drills can be exact and regular moves get smoothed out.
Steve Stallings
www.PMDX.com
Chaoticone
5,624
Precision Chaos
Reply #9 on:
July 23, 2019, 08:26:05 AM »
Good point Steve and it may be exactly what he needs to do.
If you do not have mcCvDistToleranceV001 in your wizard list you probably need to update.
Print
Pages:
1
2
Go Up
« previous
next »
