Hello Guest it is November 27, 2026, 09:21:09 AM
Author Topic: X axis skipping  (Read 15447 times)
X axis skipping
« on: July 17, 2019, 12:18:33 AM »
I have been trying to make chess pieces with the schools NC-65 lathe. The first 4 or 5 where great the they started coming out at different sizes, upon inspection i discovered the x axis was skipping then found a broken sensor on the machine. I replaced and broke that sensor (boilermaker by trade), so i got a fitter to help replace that sensor and we reassembled machine. This has taken place over 4 years. I still have the problem that the bloody thing is still moving erratically on the x axis. I have attached a video (zipped up) file any help will be really appreciated.
  •  9,379 9,379
Re: X axis skipping
« Reply #1 on: July 17, 2019, 01:06:48 AM »
Check all the mechanicals first, I mean thoroughly check.
Check that axis slide is not tight or binding.
Check tightness of motor / leadscrew couplings.
If belt drive, check belt and pulleys for condition and tightness.
Etc.
Your video sounds like the motor is stalling.
Try reducing the X axis Velocity and Acceleration by 50% in Motor Tuning and save the changes. If this makes a difference then check that the X axis motor is getting hot (less than 60 deg.C) if it is not then increase the current setting (in the motor driver) by one setting and see if this makes a difference.
Try those for starters and report back.
Re: X axis skipping
« Reply #2 on: July 17, 2019, 01:56:08 AM »
Thanks mate will do when i return to work.
Mark
