Hello Guest it is October 24, 2026, 02:50:24 PM
Author Topic: touch off feature only in the plasma screen set  (Read 5690 times)
« on: July 15, 2019, 11:07:53 PM »
So ya im lost  came on here because i want to use the touch off feature only in the plasma screen set....i jave a floating head torch mount on my z acis and im using mach 4, all posts on sheetcam dont work. Some one help!!!! Is there a post processor for mach 4 and sheetcam to make this possible or perhaps just possible o  the plasma screen set? If so what do you use as the touch off sensor? Probe g31???
Re: touch off feature only in the plasma screen set
« Reply #1 on: July 16, 2019, 07:53:39 AM »
Ess warp 9 on there website have a post processor that does what you want for mach 4 using a proma thc up down inputs .. all for mach 4
I have a hicon running mach 4 plasma 2 years now  the hicon it the only way to go with plasma and mach 4 . I used the ess and tmc3 it no hicon buy far having 5 volt I o with plasma just asking for noise in the controller  I have tested quite a fiew controllers masso also .
« Last Edit: July 16, 2019, 09:08:14 AM by Chaoticone »
