Hello Guest it is November 13, 2026, 12:06:25 PM
Author Topic: Crazy zero  (Read 8397 times)
Crazy zero
« on: July 05, 2019, 11:10:03 PM »
I have been trying for some time to get my Grizzly G0 704 mill to work correctly. Here is what happens. I did a design in Fusion 360 and did the code. When i try to start the program the tool is set to zero on the surface of the stock. When I press start the Z axis goes up usually till it hits the end of travel and keeps going loosing its place. is it with my code or is it my machine setup? I have a router that works great and this has me stumped.
 Bruce
Offline TPS
  •  2,627 2,627
Re: Crazy zero
« Reply #1 on: July 06, 2019, 01:47:23 AM »
pls post your GCode.
Re: Crazy zero
« Reply #2 on: July 06, 2019, 01:54:06 AM »
  Attached is the code
Offline TPS
  •  2,627 2,627
Re: Crazy zero
« Reply #3 on: July 06, 2019, 02:04:59 AM »
from your code:
Z0.6
G28 G91 Z0.
G90
from Mach3 GCode help:
G28 should not be used in one line with G90/G91
Switch your machine ti single BLK mode and step through code to see where exactly the move up is initiated.
Re: Crazy zero
« Reply #4 on: July 06, 2019, 08:24:33 AM »
Thank You I will give it a try.
 Bruce
