Hello Guest it is September 13, 2026, 08:32:34 AM
Author Topic: Searches restricted to Mach4  (Read 6567 times)
« on: June 30, 2019, 01:37:08 PM »
Trying to find something in the forums for Mach4 is very difficult. The high level partitioning of Mach4 helps, but the search tab still searches everything, so a keyword finds a lot of Mach3 info and then it becomes difficult to find something that works for Mach4.  Since Mach3 and 4 are really different, there should be a way to restrict searches to only the Mach4 portion of the forum. Using Mach4 as a keyword does not always work. As an example,  searches for "USB camera"  get lots of hits, but they are almost all Mach3 and so it is difficult to find a mach4 post if it exists. When I add Mach4 as a keyword, I get no hits which seems unlikely.
Re: Searches restricted to Mach4
« Reply #1 on: July 01, 2019, 07:51:51 AM »
Why not use advanced search and limit the search to the the Mach4 General Discussion board?
« Reply #2 on: July 01, 2019, 10:05:09 AM »
Thanks, that was what I was looking for, but did not see that capability in the fine print.
« Reply #3 on: July 01, 2019, 03:50:55 PM »
