Hello Guest it is November 29, 2026, 02:53:07 PM
Author Topic: Z-probing. Retract wrong distance?  (Read 20677 times)
« on: June 29, 2019, 04:52:48 AM »
Hi
I have my machine setup and working almost perfect with Mach4 and pokey57cnc. But I have an issue.
When using Mach4 for autozeroing my z, it zero as I want to. I use a 3mm block for the probing. I have stated in the value of the 3 mm int the probing software. It’s retracting the distance I want
But trying to use the machine after probing, the bit is not moving down to the surface!
I cannot figure out what’s wrong. It’s like it’s not calculating the 3 mm of my probing-plate
Best regards
Kent
Re: Z-probing. Retract wrong distance?
« Reply #1 on: June 29, 2019, 07:44:23 AM »
If you are using mm for the parameters, make sure you are in mm mode (G21).
