Hello Guest it is November 13, 2026, 03:43:56 PM
Author Topic: Linear cutting guidance  (Read 9254 times)
« on: June 27, 2019, 11:47:30 AM »
Hello all.  So i use Mach3 to run a linear cutting saw.  I make sequential cuts of a specified thickness any number of times.  Occasionally, i have to make a sequence of cuts at a different thickness immediately after i finish the first set. I have a loop that can generate the GCode for the set of sequential cuts.  I'm at a loss however as to how i can use the last X coordinate entered into the GCode list and use that as the start to add the new set of sequential cuts.  I realize i could add all of the cuts manually but i would rather i set up the screen to make the computer do it for me.
Any thoughts or ideas would be appreciated.
Peter
Offline TPS
  •  2,627 2,627
Re: Linear cutting guidance
« Reply #1 on: June 27, 2019, 01:30:34 PM »
ok i think we are talking about soemthing like this:
https://www.youtube.com/watch?v=dHXoMG2s5yE
maybe i was not able t catch the entire Problem depending on my bad Bavarian english.
just to make sure we are talking about the same Thing.
« Reply #2 on: July 01, 2019, 07:18:40 AM »
Unfortunately no that is not what i need, but thank you for the reply.
I cut small blocks of glass and need a way to program sequential cutting at 2 different thicknesses.
For Instance, Cut 4 times at a thickness of 5mm, then cutting 2 times at a thickness of 11mm.  I know what the gcode would look like I'm just at a loss as to how to get Mach3 to generate the code without me having to manually type it.  That way i can write the procedure up and teach it to other operators.
« Reply #3 on: July 01, 2019, 07:52:49 AM »
Use G91, Incremental mode.
