Hello Guest it is November 13, 2026, 10:36:38 AM
Author Topic: A problem with uc300  (Read 7696 times)
« on: June 25, 2019, 05:22:47 AM »
Hi, I have a uc300-5lpt (usb) since 3 year. i very like this card but sometime i get syncro error on usb. I tried to find a solution but i didnt find it them i bought a uc300eth (ethernet). i tried to install it with same motherboard. i just switch the card on motherboard and not change other set-up.
them i installed driver plug in for mach3 for this card. all axe work on jogging arrow.  now i try real test. after 2-3 part I realized the z axi was not at right position. I homming my z and retry, after 2 part same trouble z axi not at right position.  i made the test 5-6 time and alway same trouble, sometime after 1 par sometime after 3 part.  them i come back with my uc300-5lpt usb  and make  10 part without any trouble. I retry to install my uc300eth again and get same trouble.
i tried to change step rate of the card but not change trouble.
so do you know any solution?
i used my network configuration, if i try with cros-over wire can it fix trouble?
is it posible a bad uc-300eth??
Re: A problem with uc300
« Reply #1 on: June 25, 2019, 05:48:13 AM »
You need to contact CNC Drive. This is very strange.
