Hello Guest it is November 13, 2026, 12:18:14 PM
Author Topic: A Dumb Question?? Maybe  (Read 9284 times)
« on: September 04, 2007, 03:25:43 PM »
Hi All,
I have been running MACH3 with good success for some time on a small router with XYLOTEX driver. I am now doing a conversion of a small lathe and to test the mechanicals I used my router driver box to run the new steppers on my lathe. So the odd thing is that if I drive the lathe from MACH3MILL, I can control both X & Z axis normally and all is more or less ok excepting some backlash. However if I run MACH3TURN I cannot control the X axis, Z operates normally but no X movement at all. I have checked the config a dozen times but no luck in finding what I am missing? The motor outputs are all configured the same in mill and turn? What am I not getting here?
Any thoughts or comments appreciated
Gerald  ???
Re: A Dumb Question?? Maybe
« Reply #1 on: September 04, 2007, 04:14:59 PM »
attach your turn xml and maybe we can find the problem.
EDIT
 you will probably have to rename it to be able to attach it
