Hello
Guest
it is
September 12, 2026, 01:55:24 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Mach 3 adding symbold / characters occasionally when loading gcode.
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Mach 3 adding symbold / characters occasionally when loading gcode. (Read 8188 times)
RSM
1
on:
June 19, 2019, 10:17:43 AM »
We are having a weird issue where Mach 3 is occasionally throwing in a bunch of symbols and characters when loading a G-Code. If you open the .NC file in notepad these bad characters are not present, they are some how only appearing in Mach 3. Stranger yet, is that we will open a file one day and it loads fine, then the same file the next day will load with these extra characters. We are using Meshcam to generate the g-code. Also, we've been using Meshcam and Mach 3 with the same workflow for years and this problem has never occurred in the past, it just started doing this last week. There have been zero modifications to how we generate our code and the computer running Mach 3 is not connected to the internet or local network.
Any Advice?
Last Edit: June 19, 2019, 10:20:34 AM by RSM
Klaus1311
531
Re: Mach 3 adding symbold / characters occasionally when loading gcode.
Reply #1 on:
June 20, 2019, 05:12:19 AM »
if this happens even with the same file only occasionally, I would assume a hardware problem. Did you change anything on your computer or cabling? Is Meshcam and Mach3 running on the same computer? That can have many reasons.
Klaus
Last Edit: June 20, 2019, 05:15:55 AM by Klaus1311
The brain isn't a soap, it doesn't shrink when used.
ZASto
434
Reply #2 on:
June 20, 2019, 06:18:18 AM »
I suspect on a bad hardware, most probably RAM. Try to pull out RAM modules and plug them back tho their sockets.
Make no mistake between my personality and my attitude.
My personality is who I am.
My attitude depends on who you are.
Print
Pages:
1
Go Up
« previous
next »
