Hello Guest it is September 09, 2026, 12:47:18 AM
Author Topic: Macro Mach4 for THC CAP04  (Read 29716 times)
« on: June 18, 2019, 06:03:07 PM »
Hi Friends
In our business had been using THC CAP04 module by Agelkom since 4 years now,  but now with the new Mach4 the things has change, do you have a script or macro that replace the previous version for the module CAP04 on Mach3?
Previous Macro for mach3
Dim PierceHeight, PierceTime, Z_Min_Height, Z_Pos
PierceHeight = GetUserDRO(1000)
PierceTime = GetUserDRO(1001)
Z_Min_Height= GetUserDRO(1003)
code "G31Z"&(Z_Min_Height) // This will allow to continuously follow the curve on cutting material
While IsMoving()
Wend
Z_Pos = GetDro(2)
code "G1Z"&(Z_pos+PierceHeight) // This will allow to rise Piercing level
While IsMoving()
Wend
code "G4P1"
DoSpinCW()
code "G4P"&(PierceTime) // Wait for Piercing. Config>GeneralConfig> check G04 Dwelli in ms  box
I will apreciate
Re: Macro Mach4 for THC CAP04
« Reply #1 on: June 19, 2019, 02:54:04 AM »
I'm no expert on plasma but I believe that all the functionality required for THC is ALREADY contained within Mach4 Plasma
screenset, ie you don't need a macro, its already there as a module.
« Last Edit: June 19, 2019, 03:05:39 AM by joeaverage »
« Reply #2 on: June 19, 2019, 11:25:07 AM »
That is right. You need to start with the default plasma profile. It uses the correct screen, macros, etc. So, copy the default plasma profile and save the new as something unique. Configure that new unique profile for you machine. Should be all there is to it.
