Hello Guest it is October 24, 2026, 04:31:46 PM
Author Topic: Mach4 on Win7x86 crashes when opening dialogues  (Read 8485 times)
« on: June 15, 2019, 05:26:37 AM »
Hello there, first post here as I'm fairly new to the CNC world.
Currently setting up a small router (R-CNC from makerfr.com) with a freshly installed Win7 Home Premium SP1 x86 machine. Its got a Pentium 4 3.00 HT (3.3GHz overclock) and 2Gigs of RAM. I'm using a PMDX-416 external motion controller with the corresponding plugin and thats all working fine.
Using the demo version to test the setup.
When playing around with the steps per unit -wizard and the Mach4 control dialogue I noticed it crashes after switching dialogues a few times. And it seems to be random. At one time I could use it for like 10min switching between the wizard, the MDI and the Motor control dialogue and another time it crashed on the first try.
What I mean by crashing is that the new window doesn't open, but is visible in the taskbar. I can close it from there and re-open the wizard but its the same.
When it crashes in the control dialogue it seems to be held up during the screen refresh that it does every time it opens a dialogue and everything just freezes, I have to kill the process.
Upon next startup 90% of the time it probably works. But after opening and closing dialogues a few times it crashes again.
Any hints what to look out for? Going to try it without the overclock, I tested it with prime 95 but you never know.
Greetings from zhe Germany!
Re: Mach4 on Win7x86 crashes when opening dialogues
« Reply #1 on: June 15, 2019, 06:56:10 AM »
Mach4 takes advantage of a lot of threads to implement its functions. The Pentium series of processors have only a single CPU core and may struggle with running a lot of threads. Make sure that you have Hyper-threading enabled in your BIOS settings.
Steve Stallings
www.PMDX.com
« Reply #2 on: June 15, 2019, 07:31:29 AM »
Its on auto, I'm going to set it to enabled permanently.
I also dialed back the overclock which seems to have helped. I got one or two crashes and then it worked for like an hour or so.
I guess I have to get a more powerful machine. I had this one laying around so I used it.
Maybe one of those old AMD 8-Cores will do the trick, they're getting pretty cheap by now.
Anyway, thanks so far!
« Reply #3 on: June 15, 2019, 08:39:41 AM »
I run my machine on a dual core Atom mini-ITX board with on-chip graphics and 4G of RAM and it doesn't crash
as you have described.
Mach is not a processor hungry application, you simply don't need an 8 core CPU.
It sounds to me that you are loading your PC down with multiple threads......you could try closing one thread down before starting
another.
« Reply #4 on: June 15, 2019, 09:19:13 AM »
In this context the threads are internal to Mach4. For example, Mach4 runs at least two instances of LUA.
Steve Stallings
www.PMDX.com
« Reply #5 on: June 15, 2019, 09:24:33 AM »
Ah ok.
But what I'm doing couldn't really be described as "loading down" as I only have one dialogue open at a time and in case of the control dialogue the system is also disabled (bottom left button).
I'll keep an eye on it and report back as it seems to work half decent for now.
cheers!
