Hello Guest it is October 24, 2026, 11:00:27 PM
Author Topic: 1kW servo as spindle. Steps overflow HELP!  (Read 5419 times)
« on: June 07, 2019, 03:32:48 PM »
Hi all!
Has anyone tried this?
I've monted this in an Emco VMC-100, and it's working great! As long as I'm controlling this with 0-10V input, but wanted to try to use STEP/DIR as this is a possiblilty both in Mach 4 and in the servo, my goal is to do rigid tapping :) and with this method I'm able to go both CW and CCW.
But after a whole lot of setup and connections I finaly got it running CW/CCW!
But if I run it with M3/4 and finnish off with M5 after a while I get a warning+e-stop and the message "Motion steps overflow (-some number) check motor speed parameters"
the number in (-some number) is:
RPM=1000, some number=271
RPM=1000, some number=543( seems to double...)
anyone have encountered this?
mach4 ,pokeys57cnc (I'm only having trouble with this motor, rest working fine)
HanFre
