Hello Guest it is October 30, 2026, 11:15:38 AM
Author Topic: Screenset 2010 M3 not setting output  (Read 13391 times)
« on: June 07, 2019, 08:37:26 AM »
Hi
I am having problems where the M3 command does not set any output on Mach3. Sometimes it will work first time and always and other times it will do nothing. Not when I use the Spindle icon or a MDI command.
If I enter a spindle speed manually it shows -1  and then does not start obviously.
If I go into the setup and change nothing but use apply, it will switch the spindle on when the M3 is issued.
Re: Screenset 2010 M3 not setting output
« Reply #1 on: June 07, 2019, 08:48:42 AM »
Is it not starting because the speed is 0? How are you manually setting the speed. You should use S### in MDI to manually set the speed.
Does this mean it works with the button or MDI, or it doesn't work?
If it didn't work at all, I would guess a corrupt M3.m1s file. Some people seem to get this issue a lot.
But because it's random, I don't think so
« Reply #2 on: June 07, 2019, 12:03:14 PM »
Hi Gerry
The whole process is rather random and I am having a hard time to figure out what the correct sequence might be.
If I try and set the speed in the spindle speed box at startup it does not take it but the speed will change when I use the MDI S*********x.
I have the M3 set at output one and M4 at output 2. Sometimes the gcode (m3) will cause the spindle to turn CCW and sometimes it will turn CW. Now I have output one for both CCW and CW and then it will turn CW always.
It would seem that if I start a gcode file from scratch without any manual intervention it works mostly but if I try and run from line, it does not set any output even if I selected the spindle to be started. The icon comes on but no output.
If the speed was set with S********* and I click the M3 icon, it does not always start.
Not very sure of exactly how it works (or not) but this is as far as I can gather. If you want me to look at anything specific or any sequence, let me know what to test.
« Reply #3 on: June 07, 2019, 02:10:46 PM »
I would take a good look at  your wiring, and electronics. The only issue I've seen with Mach3 is that the spindle will not start at all. I don't think it's a software issue.
