Hello Guest it is September 09, 2026, 03:47:59 PM
Author Topic: When loading a program, the spindle starts up.................  (Read 11857 times)
Offline Tarak
  •  229 229
« on: September 03, 2007, 04:57:17 PM »
Hey this is really wierd.
When I load a program (Load NOT run) my spindle starts up on slow speed, I've recenly made the screen and designated M13 through to M16 for my spindle (see pic.)
Is M13 a reserved M code for some other purpose?
I did previously have it as M12 but had the same problem, so I changed it to M13 instead (But it's still doing it)
I'm thinking that I need to change to a different M code again.
Thoughts.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: When loading a program, the spindle starts up.................
« Reply #1 on: September 04, 2007, 03:08:14 AM »
When Mach loads a program it reads the code to draw the toolpath, any M codes you have created are also read,  what you have to do is this :-
enter this code into each and every macro you have created:
If IsLoading() Then
 ' program loading, do nowt
Else
 ' enter your existing code lines here
End If
This will stop mach3 executing the code during loading
Graham.
« Last Edit: September 05, 2007, 04:34:30 PM by Graham Waterworth »
Offline Tarak
  •  229 229
« Reply #2 on: September 04, 2007, 04:02:03 PM »
Thanks Graham, I'll give it a go.
Offline Tarak
  •  229 229
« Reply #3 on: September 05, 2007, 04:15:03 PM »
Worked Beautifully Graham, Thanks.
Darc
  •  2,785 2,785
« Reply #4 on: September 05, 2007, 04:35:20 PM »
Hi Darc,
Glad to be of help.
Graham.
