Hello Guest it is November 22, 2026, 02:24:29 PM
Author Topic: Subprogram not found  (Read 13257 times)
« on: June 05, 2019, 07:08:12 PM »
Could i get a dummies version of "how to use a subprogram from the subprogram folder"?
This is making me crazy.. I've tried so many times. Ive found threads on this and am unable to affect a solution no matter what i try!
Re: Subprogram not found
« Reply #1 on: June 05, 2019, 09:45:43 PM »
M98 (subtest.tap) L2
« Reply #2 on: June 06, 2019, 03:25:54 AM »
Where does this go?
None of the subtest files work.
« Reply #3 on: June 06, 2019, 07:20:48 AM »
The M98 is used in the gcode file to call the sub program that is in the sub directory. It is used in Mach3. What version of mach are you using Mach4 is different.
« Reply #4 on: June 06, 2019, 07:39:24 AM »
Subprogram not found solution
Subprogram not found solved.
Subprogram not found problem solved.
In an effort to help others looking for this in the future...Here's how!
Formatting is everything.
In Main program loaded into the G-code viewer or MDI- call your subprogram.
Leading zeros here are okay
ex.>      M98 P0300
In subprograms folder...
Build a text file with no extension and without any leading zeros
Name it
ex.>      O301
Regardless of body of G-code content, this file must have the subprogram name as its first line without leading zeros.
ex.>     O301
After the body of G-code content it must have an M99 WITH a carriage return following that.
As apparently the last line is not read; so it better be a "do nothing" carriage return.
ex. below
M99
          <<extra carriage return or two here
I hope this helps!
« Reply #5 on: June 06, 2019, 07:45:26 AM »
This solution is for mach4 Hobby.
