Hello Guest it is November 13, 2026, 09:36:40 AM
Author Topic: Need help with AKZ250 BOB..  (Read 8895 times)
« on: June 05, 2019, 03:09:13 AM »
Hi guys! I'm a newbie and i'm planning building my diy cnc router , i think i'll buy AKZ250 BOB Mach3 and see that it has 16 input pin , and i want to know that can use all pin input in the BOB AKZ250 to add some pushbutton to my machine as START/STOP , JOG X++.... :) :)? Because as i know that  mach3 only support pin 10,11,12,13,15 as input pin.
If only 5 pin allow i can't add some button. Hope someone help me to know , thanks for reading my topic  :) :) :)
Re: Need help with AKZ250 BOB..
« Reply #1 on: June 05, 2019, 03:23:47 AM »
Mach can handle lots of inputs, it was the parallel port that was limited.
I am not a fan of Chinese made controllers, I would recommend a better quality and much MUCH better supported controller
like an Ethernet SmoothStepper, a UC300, a 57CNC or similar, all US or European brands.
Note also that an Ethernet connected controller is likely to be more immune to noise.
  •  9,377 9,377
« Reply #2 on: June 05, 2019, 03:47:44 AM »
Don't waste your time with the AKZ250 - do as Craig has suggested and invest in a quality motion controller.
If you spend some time reading through the forum posts you will discover the AKZ250 limitations and problems that others have experienced.
