Hello Guest it is September 12, 2026, 07:29:49 PM
Author Topic: Mach4, Esc key to stop program running  (Read 7876 times)
« on: June 02, 2019, 03:41:41 PM »
How can Mach 4 be modified so the Esc key, when hit, will stop a program currently running? Like the old Mach 3 did. I tried mapping the Esc key in the keyboard inputs under plugins but I don't know what input to map the ESC key to on the Config-Inputs page to make it work. E-stop has to be mapped to Input#52 (the message that pops up if you do anything else)
Scott
Re: Mach4, Esc key to stop program running
« Reply #1 on: June 02, 2019, 04:13:47 PM »
yes that can be done.
Daz's video shows the workaround:
https://www.machsupport.com/forum/index.php?topic=31585.0
« Reply #2 on: June 09, 2019, 03:27:44 PM »
It took me abit to get the correct code for a Estop. the help file and what is in the PCL Lua code is not 100% the same.
Here is the code "I" got to work.
if mc.mcSignalGetState (mc.mcSignalGetHandle (inst, mc.ISIG_INPUT63)) == 1 then
   mc.mcCntlEStop(inst)
else
    --  Do something else
end
Scott
« Reply #3 on: June 10, 2019, 02:16:41 AM »
yes I can see how that code works, it has the advantage of simplicity but is woefully inefficient.
Mach is designed to use a signal library called SigLib in the screenload script. I wrote an introductory .pdf  about using
the signal library:
https://www.machsupport.com/forum/index.php?topic=40051.msg267764#msg267764
