Hello Guest it is November 13, 2026, 01:00:36 PM
Author Topic: 4th axis and mach3  (Read 8388 times)
4th axis and mach3
« on: May 28, 2019, 02:40:02 PM »
Ok here we go.
I am trying to setup my 4th axis in mach3. This is what I have done so far with no luck.
I have got Mach loaded on my laptop, windows 10. I have 4 NEMA 34 steppers and drivers and 1 NEMA 23 on the 4th rotary axis plus driver.
Then I have a novusun 6 axis controller USB. I have setup X,Y plus slave as A axis and Z axis in ports and pins and motor tunning. I then setup my 4th axis as the B axis. The problem I have is that the 4th axis is not turning and the DRO is not moving when I am using the MPG in mach3. When I deactivate the slave A on the Y axis then the DRO on the 4th axis starts running but the motor still don't run.
I just don't know what ells to try, please I will appreciate any help you guys and girls can give me.
Regards.
Paul.
  •  9,377 9,377
Re: 4th axis and mach3
« Reply #1 on: July 19, 2019, 05:28:03 AM »
Hi paul40,
Unfortunately Novusun is one of the businesses listed in our Hall of Shame for Mach3 Licence violation. As a result this forum does not support assistance with any of it's products unless you are a genuine Mach3 or Mach4 license holder.
This thread referrers; https://www.machsupport.com/forum/index.php?topic=24331.msg238650#msg238650
