Hello Guest it is October 25, 2026, 06:54:35 AM
Author Topic: Rotary spindle encoder setup  (Read 11454 times)
« on: May 22, 2019, 03:31:22 AM »
Good day
I bought a Optimum lathe that has the stepper motors fitted by Optimum.
It however did not have a spindle encoder for spindle speed / thread cutting.
I received a rotary spindle encoder from Optimum and fitted it.
The rotary spindle encoder plugs in with the limit switches at the Ref Switch plug on the controller.
I would really appreciate if someone can help me with the setup of this.
Regards
Adriaan  (South Africa)
Offline TPS
  •  2,627 2,627
Re: Rotary spindle encoder setup
« Reply #1 on: May 22, 2019, 05:14:41 AM »
depends on what Hardware (Controller/PP) you are using.
ive us some more Information about your Hardware (Manuals Pictures).
« Reply #2 on: May 22, 2019, 05:38:35 AM »
I am really new to this.
Some pics of the lathe and controller
« Reply #3 on: May 22, 2019, 05:40:13 AM »
Another pic
Offline TPS
  •  2,627 2,627
« Reply #4 on: May 22, 2019, 07:27:08 AM »
did a Little bit of searching. all i found is this pinout:
Pin assignments for the DB 25 male is
Pin        Application             Description
1          RELAY                    Switch output eg (motor on)
2          Direction X axis
3          Cycle X axis
4          Direction Y axis
5          Cycle Y axis
6          Direction Z axis
7          Cycle Z axis
8          4th Axis
9          4th Axis
10        Free
11        References switch Z
12        References switch Y
13        References switch X
14        RELAY Output eg coolant
15        Reference switch 4th axis
16  - 24  Free
25        OV DC, Earthing
The 9 pin connection pins are as follows for the reference switches
1    X1      Machine point of origin port 1 X Axis
2    Y1      Machine point of origin port 1 Y Axis
3    Z1       Machine point of origin port 1 Z Axis
4    ROUND TABLE
5    +12V DC
6    X2       Machine point of origin port 2 X Axis
7    Y2        Machine point of origin port 2 Y Axis
8    Z2        Machine point of origin port 2 Z Axis
9    OV DC
but not Information on witch port/pin's the Rotary Encoder will Show up.
maybeyou can run a parallel port test tool like this: http://www.xlentelectronics.nl/LPTTest/LPTTestUtilx64r.htm
and have a look witch Inputs are flashing if you turn the Encoder.
i assume you run at parallel port of your PC
« Reply #5 on: May 22, 2019, 07:36:27 AM »
Thank you so much for your assistance so far.
I will definitely try this tonight.
Much appreciated.
Adriaan
Offline TPS
  •  2,627 2,627
« Reply #6 on: May 23, 2019, 06:21:16 AM »
found some german documantation witch says Encoder index pulse is connected to pin15.
but no Information wether port1 or port2.
you can try and error, just set up ports/Pins -> Inputs -> Index to pin15 and
when you turn spindle by Hand you should see something in diagnostic Screen from turn screenset.
