Hello Guest it is October 04, 2026, 03:00:18 PM
Author Topic: Having issues loading GCode  (Read 30548 times)
« on: May 21, 2019, 08:09:33 AM »
Hello,
I'm new to all this. Built a 5x10 plasma table in my shop this month. did first test cuts last weekend. After the test cuts I purchased the license for both Lazycam and Mach 3. I'm running windows 10 on my PC. Ran fine for a handful of cuts. Tried making some adjustments to clean up the cuts. When I upload the new GCode into Mach 3 I get a "Bad Character" error message pointing at N30.
"N30 {SPINDLE}(PLasma On).
The Gcode that worked was
 N30 was G28.1 (Probe for Stock).
Re: Having issues loading GCode
« Reply #1 on: May 21, 2019, 09:06:33 AM »
Hi.
try removing the curly braces.
Offline TPS
  •  2,627 2,627
« Reply #2 on: May 21, 2019, 10:41:11 AM »
something changed
{SPINDLE} should be M3
« Reply #3 on: May 21, 2019, 10:49:06 AM »
thank you. How do I get in to modify it? Is it a setting in Lazycam?
