Hello Guest it is November 13, 2026, 10:01:07 AM
Author Topic: Limit Switch Overide???  (Read 7601 times)
« on: May 20, 2019, 04:45:59 PM »
After years of flawless operation, my Mach 3 on Windows XP finally has come up with a problem I haven't been to find an answer to in the forum...
It started with random "Art Code 9991" warnings/crashes, which (I think!) was fixed by a reinstall of Mach3. After the re-install, everything seems to working except I can't get Mach to reset the "Limit Switch Triggered" message. Nothing has changed in the physical machine set-up. In ports and pins, I can set the "Active Hi/Lo" to turn off the limit/home switch indicator lights in the "Diagnostics" screen, but this still does not allow me to Reset successfully. However, if I disable the switches in the "Post and Pins/Inputs", all axes work fine.
The "Auto Limit Switch" toggle on the "Settings" page makes no difference.
Any thoughts on how get my Limit Switches functional again??
Re: Limit Switch Overide???
« Reply #1 on: May 23, 2019, 03:49:35 PM »
Well, the problem turned out to a corrupted plug-in for the breakout board. Reinstalling the plugin (downloaded from the Artsoft site) solved the problem.
I suppose the lesson here is that a plugin that appears to be working correctly may still be causing problems in other parts of the system...
