Hello Guest it is November 13, 2026, 11:32:40 AM
Author Topic: Mach3 G91 And Reverse HELP :)  (Read 10688 times)
Mentor
« on: September 03, 2007, 03:32:07 AM »
Welcome  :)
  I have a small problem
  When in config mach3 use (Distance mode - Absolute) and (I J Mode - Absolute) then reverse mode operates is ok  ;)
  but in config use (Distance mode - inc) and (I J Mode - inc) then reverse loss reference X,Y and going an other space  :-\
  how config or how use mach3 with  a (Distance mode - inc) and (I J Mode - inc) that may reverse mode operates is ok...
  And how use mach3 with a (Distance mode - inc) and (I J Mode - inc) that may begin program (gcode) other line ? function (Run From Here) then program open window (preparation positioning) and whene accept (ok) then going on the position and runaway queer position  :-\
Please help and  indulgence for my language :)  (im Poland)
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Mach3 G91 And Reverse HELP :)
« Reply #1 on: September 04, 2007, 03:14:33 AM »
Hi Mentor,
can you post your g-code so we can have a look at it.
Graham.
Mentor
« Reply #2 on: September 04, 2007, 06:26:21 AM »
Config here -> http://medranet.one.pl/image/?dir=mach/&item=0&big=1
And Gcode ->
N0 G91 G40 F400
N2 G0 X0 Y10
N4 G0 X11 Y479.747 Z0.2
N5 G1 X+2.6 Y-7.6
N6 G1 X+6.500 Y-7.900
N7 G3 X-8.641 Y-13.321 I+1.946 J-10.725
N8 G1 X+10.801 Y-44.050
N9 G2 X-7.426 Y-13.027 I-10.586 J-2.596
N10 G1 X+5.822 Y-20.443
N11 G2 X+89.634 Y-0.796 I+43.434 J-156.173
N12 G1 X+0 Y+12.963
N13 G1 X+1.996 Y+0
N14 G1 X+6.754 Y-10.854
N15 G2 X+84.601 Y-2.109 I+38.401 J-157.486
N16 G1 X+0 Y+12.963
N17 G1 X+1.996 Y+0
N18 G1 X+6.754 Y-10.854
N19 G2 X+76.394 Y+0.099 I+38.401 J-157.486
N20 G1 X+4.886 Y+18.738
N21 G2 X-9.483 Y+2.850 I-1.946 J+10.725
N22 G1 X-67.904 Y+64.990
N23 G3 X-18.123 Y-10.470 I-7.537 J-7.875
N24 G1 X+10.800 Y-44.050
N25 G2 X-18.123 Y-10.470 I-10.586 J-2.596
N26 G1 X-67.904 Y+64.990
N27 G3 X-18.123 Y-10.470 I-7.537 J-7.875
N28 G1 X+10.800 Y-44.050
N29 G2 X-18.123 Y-10.470 I-10.586 J-2.596
N30 G1 X-67.904 Y+64.990
N31 G3 X-9.483 Y+2.850 I-7.537 J-7.875
N32 G1 X+4.886 Y+18.738
N33 G3 X+76.394 Y+0.099 I+37.993 J+157.585
N34 G1 X+6.754 Y-10.854
N35 G1 X+1.996 Y+0
N36 G1 X+0 Y+12.963
N37 G3 X+84.601 Y-2.109 I+46.200 J+155.377
N38 G1 X+6.754 Y-10.854
N39 G1 X+1.996 Y+0
N40 G1 X+0 Y+12.963
N41 G3 X+89.634 Y-0.796 I+46.200 J+155.377
N42 G1 X+5.822 Y-20.443
N43 G3 X-7.426 Y-13.027 I+3.160 J-10.432
N44 G1 X+10.800 Y-44.050
N45 G2 X-8.641 Y-13.321 I-10.586 J-2.596
N46 G1 X+11.100 Y-10.300 Z-0.2
N47 G0 X+4.300 Y+0
N48 G0 X+0 Y+96.492 Z0.2
N49 G1 X+2.6 Y-7.6
N50 G1 X+6.500 Y-7.900
N51 G3 X-8.641 Y-13.321 I+1.946 J-10.725
N52 G1 X+10.801 Y-44.050
N53 G2 X-7.426 Y-13.027 I-10.586 J-2.596
N54 G1 X+5.822 Y-20.443
N55 G2 X+89.634 Y-0.796 I+43.434 J-156.173
N56 G1 X+0 Y+12.963
N57 G1 X+1.996 Y+0
N58 G1 X+6.754 Y-10.854
N59 G2 X+84.601 Y-2.109 I+38.401 J-157.486
N60 G1 X+0 Y+12.963
N61 G1 X+1.996 Y+0
N62 G1 X+6.754 Y-10.854
N63 G2 X+76.394 Y+0.099 I+38.401 J-157.486
N64 G1 X+4.886 Y+18.738
N65 G2 X-9.483 Y+2.850 I-1.946 J+10.725
N66 G1 X-67.904 Y+64.990
N67 G3 X-18.123 Y-10.470 I-7.537 J-7.875
N68 G1 X+10.800 Y-44.050
N69 G2 X-18.123 Y-10.470 I-10.586 J-2.596
N70 G1 X-67.904 Y+64.990
N71 G3 X-18.123 Y-10.470 I-7.537 J-7.875
N72 G1 X+10.800 Y-44.050
N73 G2 X-18.123 Y-10.470 I-10.586 J-2.596
N74 G1 X-67.904 Y+64.990
N75 G3 X-9.483 Y+2.850 I-7.537 J-7.875
N76 G1 X+4.886 Y+18.738
N77 G3 X+76.394 Y+0.099 I+37.993 J+157.585
N78 G1 X+6.754 Y-10.854
N79 G1 X+1.996 Y+0
N80 G1 X+0 Y+12.963
N81 G3 X+84.601 Y-2.109 I+46.200 J+155.377
N82 G1 X+6.754 Y-10.854
N83 G1 X+1.996 Y+0
N84 G1 X+0 Y+12.963
N85 G3 X+89.634 Y-0.796 I+46.200 J+155.377
N86 G1 X+5.822 Y-20.443
N87 G3 X-7.426 Y-13.027 I+3.160 J-10.432
N88 G1 X+10.800 Y-44.050
N89 G2 X-8.641 Y-13.321 I-10.586 J-2.596
N90 G1 X+11.100 Y-10.300 Z-0.2
N91 G0 X0 Y-27.310
N92 G0 X-591.841 Z0.2
N105 G1 X+2.6 Y-7.6
N106 G1 X+6.500 Y-7.900
N107 G3 X-8.641 Y-13.321 I+1.946 J-10.725
N108 G1 X+10.801 Y-44.050
N109 G2 X-7.426 Y-13.027 I-10.586 J-2.596
N110 G1 X+5.822 Y-20.443
N111 G2 X+89.634 Y-0.796 I+43.434 J-156.173
N112 G1 X+0 Y+12.963
N113 G1 X+1.996 Y+0
N114 G1 X+6.754 Y-10.854
N115 G2 X+84.601 Y-2.109 I+38.401 J-157.486
N116 G1 X+0 Y+12.963
N117 G1 X+1.996 Y+0
N118 G1 X+6.754 Y-10.854
N119 G2 X+76.394 Y+0.099 I+38.401 J-157.486
N120 G1 X+4.886 Y+18.738
N121 G2 X-9.483 Y+2.850 I-1.946 J+10.725
N122 G1 X-67.904 Y+64.990
N123 G3 X-18.123 Y-10.470 I-7.537 J-7.875
N124 G1 X+10.800 Y-44.050
N125 G2 X-18.123 Y-10.470 I-10.586 J-2.596
N126 G1 X-67.904 Y+64.990
N127 G3 X-18.123 Y-10.470 I-7.537 J-7.875
N128 G1 X+10.800 Y-44.050
N129 G2 X-18.123 Y-10.470 I-10.586 J-2.596
N130 G1 X-67.904 Y+64.990
N131 G3 X-9.483 Y+2.850 I-7.537 J-7.875
N132 G1 X+4.886 Y+18.738
N133 G3 X+76.394 Y+0.099 I+37.993 J+157.585
N134 G1 X+6.754 Y-10.854
N135 G1 X+1.996 Y+0
N136 G1 X+0 Y+12.963
N137 G3 X+84.601 Y-2.109 I+46.200 J+155.377
N138 G1 X+6.754 Y-10.854
N139 G1 X+1.996 Y+0
N140 G1 X+0 Y+12.963
N141 G3 X+89.634 Y-0.796 I+46.200 J+155.377
N142 G1 X+5.822 Y-20.443
N143 G3 X-7.426 Y-13.027 I+3.160 J-10.432
N144 G1 X+10.800 Y-44.050
N145 G2 X-8.641 Y-13.321 I-10.586 J-2.596
N146 G1 X+11.100 Y-10.300 Z-0.2
N147 G0 X+4.300 Y+0
N148 G0 X+0 Y+96.492 Z0.2
N149 G1 X+2.6 Y-7.6
N150 G1 X+6.500 Y-7.900
N151 G3 X-8.641 Y-13.321 I+1.946 J-10.725
N152 G1 X+10.801 Y-44.050
N153 G2 X-7.426 Y-13.027 I-10.586 J-2.596
N154 G1 X+5.822 Y-20.443
N155 G2 X+89.634 Y-0.796 I+43.434 J-156.173
N156 G1 X+0 Y+12.963
N157 G1 X+1.996 Y+0
N158 G1 X+6.754 Y-10.854
N159 G2 X+84.601 Y-2.109 I+38.401 J-157.486
N160 G1 X+0 Y+12.963
N161 G1 X+1.996 Y+0
N162 G1 X+6.754 Y-10.854
N163 G2 X+76.394 Y+0.099 I+38.401 J-157.486
N164 G1 X+4.886 Y+18.738
N165 G2 X-9.483 Y+2.850 I-1.946 J+10.725
N166 G1 X-67.904 Y+64.990
N167 G3 X-18.123 Y-10.470 I-7.537 J-7.875
N168 G1 X+10.800 Y-44.050
N169 G2 X-18.123 Y-10.470 I-10.586 J-2.596
N170 G1 X-67.904 Y+64.990
N171 G3 X-18.123 Y-10.470 I-7.537 J-7.875
N172 G1 X+10.800 Y-44.050
N173 G2 X-18.123 Y-10.470 I-10.586 J-2.596
N174 G1 X-67.904 Y+64.990
N175 G3 X-9.483 Y+2.850 I-7.537 J-7.875
N176 G1 X+4.886 Y+18.738
N177 G3 X+76.394 Y+0.099 I+37.993 J+157.585
N178 G1 X+6.754 Y-10.854
N179 G1 X+1.996 Y+0
N180 G1 X+0 Y+12.963
N181 G3 X+84.601 Y-2.109 I+46.200 J+155.377
N182 G1 X+6.754 Y-10.854
N183 G1 X+1.996 Y+0
N184 G1 X+0 Y+12.963
N185 G3 X+89.634 Y-0.796 I+46.200 J+155.377
N186 G1 X+5.822 Y-20.443
N187 G3 X-7.426 Y-13.027 I+3.160 J-10.432
N188 G1 X+10.800 Y-44.050
N189 G2 X-8.641 Y-13.321 I-10.586 J-2.596
N190 G1 X+11.100 Y-10.300 Z-0.2
N191 G0 X0 Y-27.310
N192 G0 X-591.841 Y0 Z0.2
N205 G1 X+2.6 Y-7.6
N206 G1 X+6.500 Y-7.900
N207 G3 X-8.641 Y-13.321 I+1.946 J-10.725
N208 G1 X+10.801 Y-44.050
N209 G2 X-7.426 Y-13.027 I-10.586 J-2.596
N210 G1 X+5.822 Y-20.443
N211 G2 X+89.634 Y-0.796 I+43.434 J-156.173
N212 G1 X+0 Y+12.963
N213 G1 X+1.996 Y+0
N214 G1 X+6.754 Y-10.854
N215 G2 X+84.601 Y-2.109 I+38.401 J-157.486
N216 G1 X+0 Y+12.963
N217 G1 X+1.996 Y+0
N218 G1 X+6.754 Y-10.854
N219 G2 X+76.394 Y+0.099 I+38.401 J-157.486
N220 G1 X+4.886 Y+18.738
N221 G2 X-9.483 Y+2.850 I-1.946 J+10.725
N222 G1 X-67.904 Y+64.990
N223 G3 X-18.123 Y-10.470 I-7.537 J-7.875
N224 G1 X+10.800 Y-44.050
N225 G2 X-18.123 Y-10.470 I-10.586 J-2.596
N226 G1 X-67.904 Y+64.990
N227 G3 X-18.123 Y-10.470 I-7.537 J-7.875
N228 G1 X+10.800 Y-44.050
N229 G2 X-18.123 Y-10.470 I-10.586 J-2.596
N230 G1 X-67.904 Y+64.990
N231 G3 X-9.483 Y+2.850 I-7.537 J-7.875
N232 G1 X+4.886 Y+18.738
N233 G3 X+76.394 Y+0.099 I+37.993 J+157.585
N234 G1 X+6.754 Y-10.854
N235 G1 X+1.996 Y+0
N236 G1 X+0 Y+12.963
N237 G3 X+84.601 Y-2.109 I+46.200 J+155.377
N238 G1 X+6.754 Y-10.854
N239 G1 X+1.996 Y+0
N240 G1 X+0 Y+12.963
N241 G3 X+89.634 Y-0.796 I+46.200 J+155.377
N242 G1 X+5.822 Y-20.443
N243 G3 X-7.426 Y-13.027 I+3.160 J-10.432
N244 G1 X+10.800 Y-44.050
N245 G2 X-8.641 Y-13.321 I-10.586 J-2.596
N246 G1 X+11.100 Y-10.300 Z-0.2
N247 G0 X+4.300 Y+0
N248 G0 X+0 Y+96.492 Z0.2
N249 G1 X+2.6 Y-7.6
N250 G1 X+6.500 Y-7.900
N251 G3 X-8.641 Y-13.321 I+1.946 J-10.725
N252 G1 X+10.801 Y-44.050
N253 G2 X-7.426 Y-13.027 I-10.586 J-2.596
N254 G1 X+5.822 Y-20.443
N255 G2 X+89.634 Y-0.796 I+43.434 J-156.173
N256 G1 X+0 Y+12.963
N257 G1 X+1.996 Y+0
N258 G1 X+6.754 Y-10.854
N259 G2 X+84.601 Y-2.109 I+38.401 J-157.486
N260 G1 X+0 Y+12.963
N261 G1 X+1.996 Y+0
N262 G1 X+6.754 Y-10.854
N263 G2 X+76.394 Y+0.099 I+38.401 J-157.486
N264 G1 X+4.886 Y+18.738
N265 G2 X-9.483 Y+2.850 I-1.946 J+10.725
N266 G1 X-67.904 Y+64.990
N267 G3 X-18.123 Y-10.470 I-7.537 J-7.875
N268 G1 X+10.800 Y-44.050
N269 G2 X-18.123 Y-10.470 I-10.586 J-2.596
N270 G1 X-67.904 Y+64.990
N271 G3 X-18.123 Y-10.470 I-7.537 J-7.875
N272 G1 X+10.800 Y-44.050
N273 G2 X-18.123 Y-10.470 I-10.586 J-2.596
N274 G1 X-67.904 Y+64.990
N275 G3 X-9.483 Y+2.850 I-7.537 J-7.875
N276 G1 X+4.886 Y+18.738
N277 G3 X+76.394 Y+0.099 I+37.993 J+157.585
N278 G1 X+6.754 Y-10.854
N279 G1 X+1.996 Y+0
N280 G1 X+0 Y+12.963
N281 G3 X+84.601 Y-2.109 I+46.200 J+155.377
N282 G1 X+6.754 Y-10.854
N283 G1 X+1.996 Y+0
N284 G1 X+0 Y+12.963
N285 G3 X+89.634 Y-0.796 I+46.200 J+155.377
N286 G1 X+5.822 Y-20.443
N287 G3 X-7.426 Y-13.027 I+3.160 J-10.432
N288 G1 X+10.800 Y-44.050
N289 G2 X-8.641 Y-13.321 I-10.586 J-2.596
N290 G1 X+11.100 Y-10.300 Z-.02
N291 G0 X0 Y-27.310
N292 G0 X-591.841 Y0 Z0.2
N305 G1 X+2.6 Y-7.6
N306 G1 X+6.500 Y-7.900
N307 G3 X-8.641 Y-13.321 I+1.946 J-10.725
N308 G1 X+10.801 Y-44.050
N309 G2 X-7.426 Y-13.027 I-10.586 J-2.596
N310 G1 X+5.822 Y-20.443
N311 G2 X+89.634 Y-0.796 I+43.434 J-156.173
N312 G1 X+0 Y+12.963
N313 G1 X+1.996 Y+0
N314 G1 X+6.754 Y-10.854
N315 G2 X+84.601 Y-2.109 I+38.401 J-157.486
N316 G1 X+0 Y+12.963
N317 G1 X+1.996 Y+0
N318 G1 X+6.754 Y-10.854
N319 G2 X+76.394 Y+0.099 I+38.401 J-157.486
N320 G1 X+4.886 Y+18.738
N321 G2 X-9.483 Y+2.850 I-1.946 J+10.725
N322 G1 X-67.904 Y+64.990
N323 G3 X-18.123 Y-10.470 I-7.537 J-7.875
N324 G1 X+10.800 Y-44.050
N325 G2 X-18.123 Y-10.470 I-10.586 J-2.596
N326 G1 X-67.904 Y+64.990
N327 G3 X-18.123 Y-10.470 I-7.537 J-7.875
N328 G1 X+10.800 Y-44.050
N329 G2 X-18.123 Y-10.470 I-10.586 J-2.596
N330 G1 X-67.904 Y+64.990
N331 G3 X-9.483 Y+2.850 I-7.537 J-7.875
N332 G1 X+4.886 Y+18.738
N333 G3 X+76.394 Y+0.099 I+37.993 J+157.585
N334 G1 X+6.754 Y-10.854
N335 G1 X+1.996 Y+0
N336 G1 X+0 Y+12.963
N337 G3 X+84.601 Y-2.109 I+46.200 J+155.377
N338 G1 X+6.754 Y-10.854
N339 G1 X+1.996 Y+0
N340 G1 X+0 Y+12.963
N341 G3 X+89.634 Y-0.796 I+46.200 J+155.377
N342 G1 X+5.822 Y-20.443
N343 G3 X-7.426 Y-13.027 I+3.160 J-10.432
N344 G1 X+10.800 Y-44.050
N345 G2 X-8.641 Y-13.321 I-10.586 J-2.596
N346 G1 X+11.100 Y-10.300 Z-0.2
N347 G0 X+4.300 Y+0
N348 G0 X+0 Y+96.492 Z0.2
N349 G1 X+2.6 Y-7.6
N350 G1 X+6.500 Y-7.900
N351 G3 X-8.641 Y-13.321 I+1.946 J-10.725
N352 G1 X+10.801 Y-44.050
N353 G2 X-7.426 Y-13.027 I-10.586 J-2.596
N354 G1 X+5.822 Y-20.443
N355 G2 X+89.634 Y-0.796 I+43.434 J-156.173
N356 G1 X+0 Y+12.963
N357 G1 X+1.996 Y+0
N358 G1 X+6.754 Y-10.854
N359 G2 X+84.601 Y-2.109 I+38.401 J-157.486
N360 G1 X+0 Y+12.963
N361 G1 X+1.996 Y+0
N362 G1 X+6.754 Y-10.854
N363 G2 X+76.394 Y+0.099 I+38.401 J-157.486
N364 G1 X+4.886 Y+18.738
N365 G2 X-9.483 Y+2.850 I-1.946 J+10.725
N366 G1 X-67.904 Y+64.990
N367 G3 X-18.123 Y-10.470 I-7.537 J-7.875
N368 G1 X+10.800 Y-44.050
N369 G2 X-18.123 Y-10.470 I-10.586 J-2.596
N370 G1 X-67.904 Y+64.990
N371 G3 X-18.123 Y-10.470 I-7.537 J-7.875
N372 G1 X+10.800 Y-44.050
N373 G2 X-18.123 Y-10.470 I-10.586 J-2.596
N374 G1 X-67.904 Y+64.990
N375 G3 X-9.483 Y+2.850 I-7.537 J-7.875
N376 G1 X+4.886 Y+18.738
N377 G3 X+76.394 Y+0.099 I+37.993 J+157.585
N378 G1 X+6.754 Y-10.854
N379 G1 X+1.996 Y+0
N380 G1 X+0 Y+12.963
N381 G3 X+84.601 Y-2.109 I+46.200 J+155.377
N382 G1 X+6.754 Y-10.854
N383 G1 X+1.996 Y+0
N384 G1 X+0 Y+12.963
N385 G3 X+89.634 Y-0.796 I+46.200 J+155.377
N386 G1 X+5.822 Y-20.443
N387 G3 X-7.426 Y-13.027 I+3.160 J-10.432
N388 G1 X+10.800 Y-44.050
N389 G2 X-8.641 Y-13.321 I-10.586 J-2.596
N390 G1 X+11.100 Y-10.300 Z-0.2
N392 G0 X-591.841 Y0 G40
N596 M30
