Hello Guest it is November 13, 2026, 01:00:27 PM
Author Topic: OemButton 250 Help  (Read 8846 times)
Offline Davek0974
  •  2,606 2,606
OemButton 250 Help
« on: May 11, 2019, 12:00:53 PM »
I see button 250 is disable an axis movement but how is it re-enabled?
There is no opposing button code.
I am setting up my mill for turning and once positioned i want to disable the Y axis and C axis (knee) so they cant be accidentally moved or jogged
Unless there is a better way??
Re: OemButton 250 Help
« Reply #1 on: May 11, 2019, 12:43:11 PM »
It is a toggle.
Offline Davek0974
  •  2,606 2,606
« Reply #2 on: May 11, 2019, 12:46:30 PM »
Ok thanks, seems none of my documents mention that ;)
« Reply #3 on: May 11, 2019, 03:10:16 PM »
Neither do mine but I reckoned if there wasn't an enable then it would likely be a toggle so I tried it and it was.
Whether it will work with the CSMIO I have no idea.
BTW 250 is X axis, 251 is the Y.
Offline Davek0974
  •  2,606 2,606
« Reply #4 on: May 11, 2019, 03:16:14 PM »
I'll test it tomorrow, added it to my screen set ;)
